Thanks for the quick reply.
There is a handle on the pot that I'm pretty sure requires some support. Even so, can the fact that support isn't needed make the support fail when it's there anyway?
No primetower. It hasn't been necessary before. I'll try however.
The version of Cura I' m using is 4.11.0. Is that the latest?
16 minutes ago, MariMakes said:
Have you considered increasing the horizontal expansion to print more PVA so the material is properly primed?
I'm not familiar with this setting (bit of a newbie, me). What does it do?
It's someone elses project. I'll try to get a hold of it. Does it need to be saved after slicing?
Thanks again!
MariMakes 192
Hey @Gmajor,
Have you tried printing this printjob without supports?
I don't believe it needs it. 🤔
Something seems to go wrong with priming the PVA.
Are you printing a primetower?
Are you slicing with the latest verison of Cura?
Do you have a project file for us? It contains the printer and settings we need for troubleshooting.
To save a project file go to File -> Save project.
