GCode Circle
justflow
Hello everyone,
I have one i think really easy thing for you guys.
I need to make GCode for circle that starts in center of circle so i can modify center points
Every circle i make start point is on one of circle points but i need circle who starts in the middle...
For tomorow job so please if anyone knows how to do that paste me Gcode for it i need to mill it tomorow.
I will be so thankful.
There is the picture of that. Sorry it is not the good one but i am in kind of hurry :D
GCode Circle
    If youre milling with ISO coding, then i think i can help. I mainly use ISO on lathes though and not mills so i may be rusty, i use heidenhain on our mills at work. Anyway hope this helps
    If your circle is for instance 50mm diameter then this would be the coding to mill what you want
    G0 X0 Y0 (This is the centre of your circle)
    G0 Z1.0 F100 (Rapid to 1mm above the top of youre workpiece, with feed of 100)
    G1 K-1.0 (Incrementally move 1mm lower in Z)
    G1 X0 Y25.0 (Move up to perpendicular to your start point)
    G2 X0 Y-25.0 I0 J0 (Clockwise movement 180 degrees from where it is with the centre at your "start" point
    G2 X0 Y25 I0 J0 (Clockwise movement another 180 degrees back to where you started)
    G0 Z5.0
    It kind of depends what youre cutting really, ideally you should radius onto the cutting path if possible for a nicer finish. Can you explain what youre wanting to do and i may be able to assist you better :)
    Posted · GCode Circle
    G0 Z5.0
    First thanks for your post
    I am working in RepRap and I am printing some lego stuff.
    RepRap printing is really good but i needed to create Milling option witch i did
    So when finish printing need to start mill the 3 holes in that figure or model.
    It is about circle holes.
    So i programed in C# analyzer who finds middle points of that 3 holes
    So i need circle with start point from that middle point of the hole.
    I think i explained this better now :D
        How to Enter
        Design an Ornament
          Entering a new design
        Entering an existing design
        Winning designs should:
        Be original Creations
        Good luck 🎉
        • 1 reply
        • 14 replies
