Hey, thanks for the answer, but i'm not sure what you're speaking of. The model is a 1 part STL, nothing is separated in 3 parts and I'm using some Horizontal Expansion so that thin details and thin wall actually print thicker and more sturdely, in addition of merging closes surfaces together. Indeed, it looks weird as is, cause it's the upper part of a previously failed print, 3 day longs, that I did not wanted to waste, so I re-sliced the top part.
Edit : I see, i've uploaded the "Stockage" print instead of the "Top" one, sorry, indeed the stockage quite looks like 3 separated shell, but it's not, and the generous horizontal expansion makes it for toughness and merging of the geometry.
I'm also not sure how 0.8mm could be experimental as it's offically delivered by Ultimaker and it's still quite a commun size of print core. Surely it's not as widely used as 0.4mm, but that's not exotic by any way. I've reduced printing speed quite a lot, at about 30 mm/s by now, and still face a lot of trouble. The Coasting parameters is actually doing good, i've let it apart before because not mastering its effect, but looks good.
But i'm still facing lot of failures, actually NONE of the 5 last prints came to the end, all of them failed at one point, because of PVA Print Core mainly, or random error with any message, and the last one failed with a machine crash, the screen was frozen, so no message. And the AA 0.8mm seems like it ran out of material with underextrusion and no-more-extrusion. Tested it, the filament were not grinded in the feeder, and a new load of the filament went seemless.
Any idea regarding the X/Y sudden mis-alignement featured in pics ?
This machine is driving me crazy... So many things wrong about it 😞
Edited by Dadkitess
Torgeir 289
Hi @Dadkitess,
the model consist of three different part's, the main construction plus two "sheet" metal boxes floating inside the main construction. It's "impossible" to print this model like this.
The two sheet (?) metal boxes has to be printed separately, using 0.4 mm core (or maybe better with 0.25 mm).
Also the main construction (frame) shall be printed separately, but there's some details become a problem for a 0.8 mm
core.
This model will keep newer versions of Cura "seems" to hang up, but working really.
If this model is saved in stl format, -then loaded into Cura and you will see the problem.
Edit: It looks like your support structure (main frame) is not watertight as well, -but it appears that the model can be printed like this on purpose as you're only interested in this as a presentation?
Using such a large core (0.8 mm) is kind of experimental so print speed, temperature and retraction really need to be tuned. I'll see that you tested the "upper" part of the model as well, but I think the speed have to go down then you will need to reduce the temp.
Thanks
Torgeir
Edited by TorgeirAdded info.
