Distortion when using tough black PLA
Posted · Distortion when using tough black PLA
Hi, I am currently using Ultimaker S5 to print thin wall boxes using tough black PLA.
I used the default setting in Cura, but I have always observed some distortion at the initial layers while the distortion disappears later.
I attached the picture of my 3D-printed object below.
I also attached the .3mf file that I used to print the object. (Maybe a support option is not included)
Can you help me solve this problem?
UMS5_122622.3mf
    Found the problem!!!  It's the bed temp.  Okay so this is a bug...
    So you have the second core set to use ABS.  Even though it looks to me like you didn't assign the second printcore to any part.  And so there is a bug where instead of doing the normal buildplate temp of 60C it is choosing 85C.  Which is too hot for PLA (any kind of PLA - that is too hot).  So go back to the prepare tab, and disable the second printcore and reslice and you should be good.
    Although, damn, almost 2 days to print that!  I don't have that kind of patience.  I would do an AA 0.8 printcore and set layer height to maybe .3mm.  .1mm is okay for small prints but this is pretty big.  some people hate layer lines but I prefer them.  Let's people know it was 3d printed.  those two changes alone gets it down to 12 hours.  I'd keep working on lowering that.
        How to Enter
        Design an Ornament
          Entering a new design
        Entering an existing design
        Winning designs should:
        Be original Creations
        Good luck 🎉
        • 11 replies
