- Solution
If you look in PREVIEW mode at your sliced model in cura, set the view mode to "line type" and make sure the "travels" are checked (blue). The travel moves come in two colors - light blue and strong/saturated blue. Light blue is a retraction move. darker blue (as shown in MariMakes photo) is non retracting. There are quite a few settings that can control which type is chosen so if you have this problem again, check the blue colors and then look at all the retraction settings.
1
gr5 2,330
PLA is usually pretty good about not stringing. Unlike some other materials which need to be dried to avoid the stringing.
Are they extremely fine hairs that are hard to see? Those are the hardest to get rid of by messing with settings but the easiest to get rid of after the print is done. I get rid of most of those with a flame. I use a butane torch - around $10 on amazon. I give the strings a quick swipe covering maybe 5 inches per second so each spot gets only maybe 30ms of flame. No. Faster than that. Maybe 15 inches per second. The fine hairs are then gone. If you move the flame too slowly you brown or blacken the pla.
You shouldn't get thicker strings. Those are more likely for larger nozzles (so stick with 0.4mm if you want to get rid of them) and they are more common if you are printing faster. For a really beautiful print I set all the speeds to 35mm/sec (infill, inner, outer walls, bottom, top speeds). But leave the travel speed as fast as possible. 300mm/sec travel speed is probably reasonable - I don't usually go that fast but it should help the stringing. If you go too fast then you will miss a step on the stepper and the whole part will shift on some layer. But 300mm/sec should be fine if you keep your rods oiled - just one drop only about once per month on the 6 rods in the gantry. Any light mineral oil is fine. 3-in-1 oil. Sewing machine oil. Any mineral oil. Even baby oil is probably okay. wd-40 is not great - it's meant for cleaning - not so much lubricating.
Higher printing speeds means higher pressures in the nozzle.
I wouldn't mess with retraction speed or distance but if you mess with the distance: The distance should be the right amount so that the filament is no longer pressurizing the nozzle but not enough to actually pull upwards and allow air into the nozzle. So if you look at the bowden at the top of the arc while it's doing the retractions you can see the filament come down and rest on the bottom of the inside of the tube - it's easier to see what I mean if you watch it happen. But if you look down where the filament enters the print head it should never move upward on a retraction.
Check your bowden to make sure it is not loose - pull up on the bowden and it should not move up. Both at the head and the feeder. If it does then it wasn't inserted properly - remove the horse-shoe clip - push down on the outer collet and then push down on the bowden and then while pushing down pull up on the collet and then insert the clip. The bowden should not move up and down. If it does you can add that movement to the retraction distance.
Did you mess with any other settings? Lots of things can make it string - I'd stick to the profile where possible.
Lower temperature can also reduce stringing. Some print as cold as 180C. I use the default temps in the profile.
MariMakes 208
Hey @Lodden,
Welcome to the Ultimaker Community 🎉
Is there a chance that your doorways are placed less than 4mm apart?
For thinner models we've seen that they needed to be 6 mm apart before getting retracted.
These dark blue travels indicate unretracted moves:
We've seen that these tiny travels are not retracted in the more recent versions of Cura, eventhough we would expect them to be. We concluded that you can restore the retractions if you disable the setting: Limit Support Retractions
We actually plan to remove the setting in the next version of Cura, so the moves are retracted again.
Was that the kind of information you are looking for?
Would you be comfortable sharing a picture of your printed part quality?
That helps with troubleshooting. 😉
Lodden 1
Thank you for good responses. The gaps are indeed less than 4mm.
This model was printed with recommended settings.
