G code error
Leggy
Go to solution Solved by Leggy,
Posted · G code error
Hi all
I’m having a problem with g code transfer in version 5
I’ll post an attachment
When I save to removable, I check in finder (Mac) to look at the g code as it was 13mb!!, where as it should be about 800kb
i opened it and it wasn’t g code but gobbledygook 2nd picture
1st was done in 4.13
thanks Dean
    Hey @Leggy,
    Could it be related to the Duet RepRapFirmware Integration?
    Are you getting the same result if you disable the plug-in?
    If that's not it, I'll need a little bit more information from you.
    Do you have a project file for us? It contains the printer and settings we need for troubleshooting.
    To save a project file go to File -> Save project.
        How to Enter
        Design an Ornament
          Entering a new design
        Entering an existing design
        Winning designs should:
        Be original Creations
        Good luck 🎉
        • 1 reply
        • 12 replies
