Export files with the profile name in the filename?
echan42
Go to solution Solved by MariMakes,
Posted · Export files with the profile name in the filename?
When exporting or saving files to cura I get the following default name "CE3E3V2_Frame 1x5 Skadis" Is there a way to export the files with the profile used to slice?
For example if my file is "Frame 1x5 Skadis" have the default filename as "PLA 0,6 Nozzle Frame 1x5 Skadis"?
    • Solution
    Hey @echan42,
    Welcome to the Ultimaker Community 🎉
    There is a plug-in where you can define a number of details that will be put in the printjob name.
    Things like "{printer_name}, {printer_name_full}, {printer_type}, {printer_type_full}, {layer_height}, {machine_nozzle_size}, {infill_sparse_density}, {speed_print}, {material_flow}, {profile_name}, {profile_name_full}, {material_name}, {material_name_full}, {material_type}, {material_type_full}, {material_weight}, {print_time_hours}, {print_time_minutes}, {date_iso}, {date_year}, {date_month}, {date_day}, {time_iso}, {time_hour}, {time_minutes}
    It's called the Printjob Naming plug-in and it's created by our lovely community member @fieldOfView
    You can get it here: https://marketplace.ultimaker.com/app/cura/plugins/fieldofview/CustomJobPrefix
    Is that what you were looking for?
