It needs to be dead simple, no blocker, no parts added to declare that "this zone" should be ignored. By default, what's outside the box won't be printed, with a warning popup and that's it 🙂
Fair enough, though, some easy to use "print blocker" with custom shapes could be interesting. I find the Models Parameters to be reaaaaaaally confusing and anti-ergonomic.
I'm not familiar with Github, but I might give it a go, thanks for the recommandation.
GregValiant 1,110
If you would post this as a feature request over on GITHUB it will be seen by more of the developers. I'd like to see this as well. It should be doable to put a Support Blocker in as a Mesh Modifier to cut off the offending piece so it is ignored. It is not currently possible though.
