tinkergnome 924
On 2/2/2023 at 4:49 AM, Twwety said:i'm looking to keep the extruder temps stable at 240
You do not mention the version of Cura you use, but it should be something like this:
- if Cura runs in "Recommended Mode", switch to "Custom" mode first
- use the term "Temperatur" in the searchbar to filter the settings
- the result should be a list of (at least) 7 temperatur settings (below the "Material" heading), 2 for the buildplate and 5 for the nozzle
- set all 4 printing temperatures and the standby temperature to 240
GregValiant 980
Get everything set up in Cura and ready to slice. Use the "File | Save Project" command and post the resulting 3mf file here. Someone will take a look. You could post that gcode file as well.
