thanks alot mate, thats done the trick cheers
You can also grab the Zstage by the end near the rods, and lift it up manually.
That way you do not have to wash your hands
Awesome Hitman, congrats !
The manual doesn't mention the glass bed... I switched my printer on and the whole thing made a dreaded noise, then the bed was released... it seems ok Phew !
Cheers mate
yeh theres a few things missing from this manual lol, ive got the online one open too just incase either or is missing something. Just need to clip this glass in now and were ready to fire her up
Check out my thread in Questions & Answers... " First Print right out the box " or something like that, on Page two you`ll see my go at it all haha
I think i read it the other day lol, ill have another flick back through now though. Anyway powers on and its alive!
The excitement of the first little robot being printed is sooooooooooo cool !
i cant wait, on levelling the bed now. If only i could find my feeler gauges lol
Just do what I did, guess it
oh its not liking the insertion of new filament, i duno if its not going through the hole on the inside but it sounds like its really struggling
i found a steel rule that was a mm thick and just had to really wiggle the tube to get the filament to pass through. its feeding its way in as we speak
Print-O-Clock
i just fired hot plastic all over lol, but its now preparing to do the little robot
its printing but i think the nozzle may be blocked as theres barely any plastic coming out :(
Well none of those came out too well, i cleaned the nozzle and manually brought filament through it but when printing it either doesnt stick or the nozzle is too close and its removing itself as it lays down material. Once its shifted a bit its melting to the end of the nozzle and clogging. Ill try re calibrating the head.
Make sure that the bed is either very clean (no oily fingerprints or other residue) or put on a bit of glue stick if the PLA refuses to stick. And of course make sure it's nice and level like you're already attempting. My personal preference is also to print a thinner first layer than the default 0.3mm which I think is too thick and causes more problems.
Ill give it a go. ive just reset the bed, which appeared to be too close on the left and right edges. i duno if i was resting on something the first time and getting false results so we'll see now. Shall post results shortly
Hmm well i reset it and glued the bed, tried again and still nothing. Im wondering now if the nozzle may be blocked. I tried extruding by had and its doing nothing now. Time to tinker i guess
Welcome to 3D printing haha... Keep us posted what happens. When you prepare a print and the head starts heating up, does the PLA start running out ?
the first time it did yeh, but not anymore. I might get a pin and try and free up anything stuck in it
You can go into maintenance on the printer menu and heat up the nozzle too....
yeh im in that at the moment, well the move material section,. It says to spin the wheel to flow material through at 210 degrees but its coming out very slowly if at all
When you do 'move material' is it even trying to extrude? Does the extruder gear on the back turn). If you spin it anticlockwise, you should be able to see the filament moving backwards in the tube (watch the teethmarks in the filament closely to see it moving).
There was a bug in the firmware until fairly recently that sometimes stopped move material from doing anything. Power cycling usually fixes the problem. There have been other problems to do with aborting prints etc that might be causing you problems too, I suggest you install the latest firmware by getting the beta version of Cura, and then connecting to the printer over USB, and doing 'Machine -> Install Default Firmware'.
(The latest beta version of Cura is at http://software.ultimaker.com/Cura_closed_beta/)
Top Posters In This Topic
28
11
4
4
Popular Days
Mar 3
29
Mar 4
8
Mar 8
7
Mar 10
2
thehitman04 28 posts
skint 11 posts
illuminarti 4 posts
gr5 4 posts
Popular Days
Mar 3 2014
Mar 4 2014
Mar 8 2014
Mar 10 2014
gr5 1,968
Don't turn it on. Grab the screw and twist it and the bed will rise up. Expect to have to wash your hands after as the screw is covered in green grease.
