Skirt and rafts
Leggy
Posted · Skirt and rafts
Hi @Leggy,
Greg is right, your model is somehow skewed, -and this happen to any of us sometimes.
When you install into another slicer it's approaching the right way "always"..
So, turn your view into the underside of your build place then you can see that the model is not touching all around as is should.  If you also look around at the low bed level, turning your object or more correctly your viewing point -you'll see this opening that's making this happen.
Thanks
Torgeir
    This is looking up through the base of an Ultimaker S5 so there is some shadow structure in the way.  This is what Torgeir is talking about.  The "cyan" color means that surface is resting flat on the build plate.  The skirt won't be sneaking under this model.
    Yes, it's a shot with the build plate rolled over so the camera is pointed at the sky (if there was a sky).
    This is where I’m confused, i put it cura with the skirt and i get the head cut off , i turn skirt off and it prints perfect 🤔
    And as i showed before its cyan on the base….
