I'm willing to bet good money that you're experiencing "skip back" due to the printer not being able to give you the volume/sec that you're asking from it. I'm assuming you're hearing a "tock" sound and the filament jumps back in a split second rather than hearing the controlled and a fair bit slower normal retraction?
If you're not sure which one it is, it's easy to verify by simply printing slower and see if it still happens. Try 50mm/s or even 40mm/s and see how that goes. If the print works fine at that speed you'll know that it's the former I described above (and I'm 99.9% sure that's the case).
You can try the test in the following thread to see what your limit is at the moment. Lots and lots of experimentation is being done to increase this limit.
http://umforum.ultimaker.com/index.php?/topic/4586-can-your-um2-printer-achieve-10mm3s-test-it-here/
SandervG 1,519
Are you saying your print still retracts even when you do not have retraction enabled?
On the screenshots however I do see retraction enabled..
At what speed and distance are you retracting?
Could you check if the grubscrew on the teethed gear is still secured and super tight?
You could test this by manually trying to hold back your filament?
Do you see the teethed gear slipping on the Extruder motor?
You could also put a mark on the extruder motor and the gear an see if this mark shows any off set after a print.
At what temperature are you printing?
80mm/s is maybe a bit fast for default temperature (depending on what filament you have).
