Stringing problems
Posted · Stringing problems
Hi I'm having trouble with my slicer I think I messed up the setting to the point where even the combing and retracting distance aren't working I really need help or if anyone knows how to fully rest the software that would help I tried uninstalling and reinstalling but it didn't fix the problem I also tried other advice and so far none of them work I pretty sure it might be a corrupt file because the photos I post are of the models I used before the problem started
    • 2 weeks later...
    Hey @Cosplay101,
    I'm seeing a lot of retracted moves, those are the light blue ones.
    Unretracted moves are dark blue. So this print looks quite okay to me.
    Can you help me understand what you are trying to do?
    Do you want less travel moves? Or do you want to speed up your print?
    Do you have artifacts on your surface that you want to reduce?
    What do they look like?
        • 28 replies
