Posted
· Missing elliptical printer can't add in 5.3
Setting the bed shape seems to be broken indeed. Changing the shape options does not seem to "take". This is a bug that needs to be fixed. I think this is the same issue that is reported here:
I thought the printers and profiles synced from the account. (?)
No, not from the Ultimaker Account. At least, not automatically. I think you can create a backup in 5.2, and restore it in 5.3.
However, Cura 5.3 should on first run "find" your 5.2 profile, and make a copy to use for Cura 5.3. If that did not happen, then please try the following:
* In cura 5.3, go to Help -> Show configuration folder.
* Close Cura
* In the folder that opened in the first step, go up one folder, then locate the folder named "5.2"
* Copy - don't move - all the files in that folder to the folder named "5.3".
* Restart Cura
This should get you the configuration you had in Cura 5.2, updated for Cura 5.3.
ahoeben 1,770
https://github.com/Ultimaker/Cura/issues/14795
* Close Cura
* Restart Cura
jwhils 2
Thank you. I will try that! I also submitted a bug report.
ahoeben 1,770
Thanks for submitting a big report. It will likely get marked as a duplicate of the existing one I referenced.
