After a crash i am unable to move the printer along the Zaxis
Posted · After a crash i am unable to move the printer along the Zaxis
Hello
I use a Cellink BioX Printer
I use Cura to slice my objects
It used to work just fine but after a crash i had to use backup and reset option
After that all the G codes that are generated by cura don't print on the surface
When i adjust the Z manually it prints but on the same layer instead of moving along the Zaxis
I uninstalled the software and then installed it again but it has the same issue with no movement along the Z axis
My old g codes still work properly
Gcode that my friend made also work properly
My Start Gcode
G90
G21
My End Gcode
G1
Z30
This G code was working properly prior to the software crash
Hope someone help me with this
Thank you
Printer Issue.zip
        • 56 replies
        • 34 replies
