Query per-object settings for post-processing script development
So basicly, you can get all the keys of a profile by using getAllKeys().
So you would need to do something like:
for container in stack:for setting_key in container.getAllKeys():print(f"{container.getName()}: {setting_key}: {container.getProperty(setting_key, 'value')}")
I didn't actually check that code, so you might need to change some things to get that to work.
If you want to know if an object has per object settings, you wil need to check it's decorator. So you will need to loop over all objects in the scene and check if they have any settings in their per object stack. There isn't a global function to get all of them (as we only do this in the CuraEngine plugin and it's never re-used anywhere else)
Edited by nallath
1
nallath 1,113
You might also want to check the godmode plugin, which already does some of the things that you're asking for (https://github.com/sedwards2009/cura-god-mode-plugin)
Walking over all stacks and figuring if they have an actual value set is done (although with more logic than you would need) in the SettingInheritanceManager: https://github.com/Ultimaker/Cura/blob/f130eb2e7cafdec78849d5763f2914d609691718/cura/Settings/SettingInheritanceManager.py#L171
