Well.. 5.5.x is incredibly old firmware..
There has been.. actually an uncountable number of updates to the firmware since that version number in relation to this issue and the cause of it..
I would recommend swapping motors (and cables) to verify if it still does not work.
If it does not work after those tests, you will need a new mainboard because the stepper driver has died.
Dustin 129
