New S7, having a terrible time getting first layers to adhere (video included)
Posted · New S7, having a terrible time getting first layers to adhere (video included)
I have a relatively new S7 and I'm having a terrible time getting first layers to adhere to the bed at all. (The build plate is one of those flex plates that magnetically snaps to the bed.)
Doesn't seem to be specific to material, as it happens with both PLA and PVA, and doesn't seem specific to material source either, as it happens with both Ultimaker and 3rd party materials. It just seems to be luck if the first layer actually sticks to the bed.
I've had an Ultimaker 3 for years (with a glass plate) and never had issues with it adhering to the bed. (Occasionally there was a leveling issue that created rough first layers, but adhering was always fine.) I never had to use any special things like glue or anything like that. It just worked. For years. With the S7 it seems to be random luck if it adheres well. It worked well for the first month or so, but now it's probably 1 out of 5 print jobs that actually adheres correctly. The rest I have to abort even before the first layer is done.
It just doesn't seem to stick to the build plate material very well. It seems extremely easy to pull off. You can see in the video how easily it peels up just from the print head passing by it.
I've attached a video of a particularly bad example I just had happen. This time it barely stuck at all and started building up on the print core instead of printing on the build plate.
I've tried cleaning it extremely well (with 99% IPA). I've had it run the leveling diagnostics. I've tried tweaking various first-layer settings in Cura. Nothing seems to help.
Any suggestions or help would be hugely appreciated.
Here's the video:
https://drive.google.com/file/d/1oAU8He2N2TS7MG3Y9TNsxEu2IZobgMA1/view?usp=sharing
Printer: Ultimaker S7 (w/ Material Station)
Printer Firmware: Latest 8.2.0
Cura: 5.3.1
    your bed is dirty.
    The flexplate is considerably more sensitive to skin oils and such than the glass beds are, it needs to be cleaned.
    Guide for cleaning here: https://support.makerbot.com/s/article/000002864
    Additional resources for the flexplate here: https://support.makerbot.com/s/article/000002862
    Unfortunately that doesn't seem to change things. I cleaned it extremely well just now, exactly following the linked instructions using 99% IPA.
    This is a video of the result of the next print (it failed):
    https://drive.google.com/file/d/1oBw5W9ojY2z0aN6p9wKgErChLI7vWAjw/view?usp=share_link
    Just to make sure it wasn't my PLA, I opened a brand new package of Ultimaker magenta PLA and tried with that, also with the same result. (Actually it was worse, because it dragged the prime blob over to the middle, since even the prime blob wasn't adhering well to the plate.) I have a video, but accidentally hit the slo-mo button right before hitting record, so the recording is like 7 minutes long and in slow motion (and at half-resolution). I'm happy to upload it as well, though, if needed.
    Also, prior to my post here on the forum, I had tried using the other side of the build plate as well, just in case. Just as a note, since purchasing the S7 a couple months ago, the build plate has only ever been cleaned using 99% IPA and only with a microfiber cloth. (I even bought brand new microfiber cloths, just to make sure.) I've used no adhesives or anything other than printing directly on the build plate. (Never used paper towels, water, or anything like that.)
    I did another test, this time with the same Ultimaker magenta filament that failed last time, but this time moved to Extruder 1, just in case maybe it was the extruder, not the material or build plate. But it failed as well. Here's the link to the video of it failing:
    https://drive.google.com/file/d/1oDEzGFgPr7fzEPA7ALKqaia5aI8weOfw/view?usp=share_link
    In between this failed print and the last one, I also did all the 1- and 3-month maintenance actions, just to make sure it wasn't anything like that either.
    Thanks! I actually opened a ticket yesterday and am in contact with them and we're trying to debug it. I will post back here with whatever gets figured out in case it can help anyone else with a similar issue.
    Any luck with figuring out what the issue was?
        • 56 replies
        • 29 replies
