1 hour ago, GregValiant said:It might if this was MakerGear Cura. Since it is Ultimaker Cura it doesn't work that way.
It's also an application designed to work for other printers as well so that's kind of a narrow view. Especially since the software already changes various settings by enabling/disabling the individual extruders.
The suggestion to setup a second printer might be the way I have to go though so thanks for the suggestion. My printhead actually has the ability to move completly off the right side of the bed to facilitate nozzle purge operations.
GregValiant 1,231
My understanding is that it is always assumed that the left nozzle can reach the left side and the right nozzle can reach the right side and that neither nozzle can move beyond the limits of the bed.
It sounds like your right nozzle can actually move beyond the right side of the bed.
I think you will need to install a second printer in Cura with the X dimension of the bed 31mm wider than the bed really is. Use that printer when you want to print with extruder 1 only, and use your original printer instance when you want to print with both extruders.
When printing with "extruder 1 only" you will need to remember that the extra 31mm you see on the right doesn't actually exist so don't put models in that area.
