Optimizing layer start and end points to prevent travel
Posted · Optimizing layer start and end points to prevent travel
Is there a setting to force the start point and end point of a layer to be the same (or as close as possible)? Or is there a setting to force the start and end of the infill to be closer to the Z seam?
With default settings, my print completes the wall, then travels all the way across to the other side of the body to start the infill, then finishes the infill and travels all the way across the body again to the Z seam to begin the next layer.
    With the Custom setting button turned on and the Setting Visibility turned to All then in the Travel Section you will find "Layer Start X" and "Layer Start Y".
    There is no such setting for the infill.  It will often be as you want it (start near the z seam or layer start point) but for different types of infill patterns it may be different and if you change the Infill Line Directions it may be different.
        • 56 replies
        • 34 replies
