Posted · How to Print Support for just a few few layers ?
So I can't try the 5.4 yet but I've faced some "issue" with the 5.3 Tree Support that might be useful.
I very often use the PVA support and often print part that don't have a single flat surface to be printed on, PVA is a good solution to make a soluble bed that will hold the whole thing while preserving the bottom curvature.
But it works well especially with basic support, like this :
The Tree Support will be a mess of tiny branches that will grow for as low as a few 0.1mm layer, and then we have the interface 80% dense support, and then the actual print.
You know how PVA is difficult to print, it WANTS to fail so these little jags everywhere are really really not a good idea.
But I'd like to use Tree Support more often, for instance in this very same print, it would be convenient.
So yeah, is there a way to avoid this weird way to print support when there is very few layers ? This is something that we face a lot whenever there is a rounded edge at the bottom : sure, it's something that you want to avoid by design but sometimes it can't be avoided.
    Hey @Dadkitess,
    I split off your issue from the 5.4 beta thread because, as you mention yourself, it's more related to Cura 5.3.
    I agree that these kinds of surfaces are not ideal to be supported with tree support.
    I believe that if you use a finely tuned standard support, perhaps a pattern like Lines would help better here.
    Maybe there are other on this forum who have suggestions on how to print something like this
