Supports first layer is not right
Posted (edited) · Supports first layer is not right
please see images attached - first layer is mistamtching with the layers above.
this is Version 5.4
5.3 didn't even have first layer
Any ideas?
Edited by Aurarum
    Posted · Supports first layer is not right
    Enable a "Skirt" and see if it improves.  The bug in 5.3.1 occurred when "Support Brim" was enabled and Bed Adhesion was set to "None".
    Greg, these images are from 5.4 - is it the same bug?
    Can't tell without a project file.  Use the "File | Save Project" command with the model loaded and Cura set up as you like.  Post the resulting 3mf file here.
    If the problem was resolved by changing to a Skirt/Brim, then I would guess that it's the same bug.
    same issue - first layer is different. I have attached the project file.
    also it appears that it is no longer possible to select multiple STL files at once and you have to open one by one
    VEGA300_belt10.3mf
    I don't have a printer definition file for you machine so I only get the model.
    With my settings profile and Skirt and Enable Support Brim enabled this is the first layer.
    With the Skirt turned off and Build Plate Adhesion at None...
    2nd layer.  The Support Structure is being extruded  where the periphery of the Support Brim is supposed to be.
    So I would say that yes, this is the same bug.  Were you able to get the Support Brim working?
    It is not behaving at all.
    I have attached my config folder - I don't think it has anything to do with the machine settings.
    5.3 is not much better - similar either why I try to do it
    machine_instances.zip
    The way I've been able to duplicate the problem is with Skirt Brim enabled and Bed Adhesion set to "None".
    This is your Vega 3 project.  Support brim is turned off.
    If you feel it is a different bug then you can fill out a bug report over on Github.
