Ultimaker Nylon does not stick to the flexiplate on S7 without glue
Posted · Ultimaker Nylon does not stick to the flexiplate on S7 without glue
Good Morning,
Ultimaker states that we can print Nylon on S7 flexiplate without any glue.
I tried printing on the flexiplate without glue. It did not stick to the flexiplate.
Then I tried with magigoo glue and it stuck to the plate.
So shall I keep using the glue for Nylon? because Ultimaker states that we should not use the glue unless specified by the material manufacturer.
Thank you,
Regards,
Deepak.
