3mf attached.
The PVA is standard PVA, the model builds fine. It just seems to me like the feed rate for the tree supports is too fast so not enough PVA in the structure, and they need a brim to give them better support.
But very glad to see the tree support, much needed in Cura.
Edited by benclewett
GregValiant 1,488
If the model isn't proprietary use the "File | Save Project" command and post the 3mf file here.
I typically run Support Flow and Support Interface flow at 90% to make them weaker and it prints fine and the support does break out easier. I'm thinking you either have a flow issue or poor layer adhesion.
What material is that? Silky PLA has inherently poor layer adhesion and generally needs to be printed at higher temps. In my case that's 215 instead of my normal 205.
