Posted
(edited)
· UM2: Nozzle not heating up anymore
Hi Sebastian,
Were you able to remove the broken heater cartridge out of the heater block? If so how?
I have this same problem. I think the heater cartridge fused with the heater block due to a tight fit and a long print.
A while ago I had some heater blocks locally made. I was surprised that the technical drawing of the heater block (provided at the Ultimaker GitHub repo) did not specifiy the diameter of the hole for the heater cartridge.
Attached is the technical drawing of the heater block.
Does anyone know what this diameter should be? Since the heater cartridge has a 4mm diameter should the heater block hole for it have a 4.1mm diameter? Or should it be greater still? How much does the heater cartridge expand when it is heated? How much does the heater block hole expand when heated?
I had the same problem. At very beginning I thought the nozzle was blocked as no filament came out, so I followed the Atomic Method to try to fix it, then found nozzle was not heated. I reset the 3D printer and the nozzle was heated now.
leonardo-aguiar 1
Hi Sebastian,
Thanks for helping guys.
Best regards.
Leo
