18 hours ago, Build-0-Matic said:I'm happy to hear that I'm not alone having problems with Cura 5.4
You're far from alone. Almost everyone has various problems with 5.4. Most of us here on the forums are wondering why they haven't pulled the download until they can release a version sans bugs.
Build-0-Matic 0
I'm using it on an Ender 3 Pro that is hooked-up to Octoprint running on a RPI.
While the printer will print properly from Octoprint, the problem I run into is that my former speedy and good profiles stopped working well when I upgraded from 5.3
I did have to fix a few issues (like changing the bowden tube), but the results were still just horrible. So I had to modify my fast profile to fit the change... been on this case for a few days now printing calibration cubes and tweaking.
I had bad layer adhesion, bad infill adhesion, holes in the sides (???), holes on top. My cubes looked more like swiss cheese than anything else.
Now, I'm just struggling with the walls separating...
But to confirm that it was Cura, I printed a cube I had saved on the Octoprint. It had been made with version 4.x and it prints absolutely beautifully, so now I need to figure out what is wrong... not obvious.
