No way...I even used fusion 360 and cut off 1mm from the bottom just to get it "flush" and nothing changed. I activated the tree supports and cura doesn't show the supports either.
FWIW I'm using Cura 5.3.0
Thoughts and comments most welcome. Thanks.
Dustin 193
UltiMaker Cura thinks the model isn't flat, because the model isn't flat..
The red areas are because they need to be supported.
Its model isn't flat
