Installing *.bin Firmware Update using Cura
njsokalski
Posted · Installing *.bin Firmware Update using Cura
I am attempting to update the firmware for my Creality Ender 3 S1 Plus using Cura. However, because the update is a *.bin file rather than a *.hex file, I am not sure if I am able to do it using Cura. Can I do it using a *.bin file the same way I would a *.hex file?
    Hi @njsokalski,
    I'll don't think that Cura handle *bin files, as that's typically later AVR stuff, -but I'm not absolutely sure.
    However, -would it not be easier to install this "FIRMWARE" file into the SD or micro SD card and upload it direct from here?
    Arduino have the possibilities to do this if you know this software.
    Thanks
    Torgeir
