How do I add a new printer definition to the linux (appImage) version of Cura?
alf5
Go to solution Solved by alf5,
Posted (edited) · How do I add a new printer definition to the linux (appImage) version of Cura?
I have a new Elegoo Neptune 4 printer.
I found some JSON definition files for it here (reddit)
I was wondering how to add these files to Cura considering it is an appImage?
I did find a "$HOME/.config/cura/5.4" directory - do I add the JSON files there? what is the structure of this directory?
p.s.
When I click the menu item "Help -> Show Configuration Folder", nothing happens
Edited by alf5
    • Solution
    Posted · How do I add a new printer definition to the linux (appImage) version of Cura?
    I think I got it.
    I extracted the appImage (using --appimage-extract switch) and can execute it running the "AppRun" program
    This time when I click "Help -> Show Configuration Folder" it launches my file manager (Dolphin in my case) in the "$HOME/.config/cura/5.4" AND "$HOME/.local/share/cura/5.4"
    For anyone else coming here in the future, the answer is "$HOME/.local/share/cura/{version}"
    You DO NOT have to extract it.
    I now have another problem, those definition files do not work, I get a "unable to slice" error...
