Adjusting Estimated Print Time
Prolectrico
Posted · Adjusting Estimated Print Time
I have a off brand 3d printer, the estimated print time displayed in Cura is always about 30% less than it actually takes. Is there any way to adjust this so I can get a more accurate display without doing mental arithmetics?
Thanks
    Not that I know of, sorry. Looked through Cura settings, Cura's configuration file and printer settings definitions. I will be happy if someone more experienced than me can correct me though.
    It might be doable in a plugin (I couldn't find any, I really need to learn the Cura API sometime) but on that front your best bet is if @ahoeben has any free time.
    Posted (edited) · Adjusting Estimated Print Time
    Ah Ha!!  Another beta  tester.
    What we have here is a proposed Post Processor that will do this and, as an added bonus (added during the University of Michigan football game yesterday) calculate the "Finish Print" time.
    Unzip the file and put "DisplayInfoOnLCD" into your Configuration Folder in the "scripts" folder.  It will be available like any other post processor under "Extensions/Post Process/Modify Gcode" and then "Add a Script".
    Enter the "Time Fudge Factor" as a percentage as "Actual Print Time / Cura Estimate" so in your case the Fudge Factor would be 70%.  Over time you can get it really close.
    The "Finish Print Time" pops up in a message box (when you save the gcode) and uses the Fudge Factor to calculate when the print will end, and adds 10 minutes (to get the print started).  There is an option to turn the message off as it can get annoying when slicing and saving repeatedly.
    DisplayInfoOnLCD.zip
    The message looks a lot like this.
    Edited by GregValiant
