ultimaker cura 4.13.1 and flying bear ghost 5 skipping to 99% of the print.
AndreLuis
Posted (edited) · ultimaker cura 4.13.1 and flying bear ghost 5 skipping to 99% of the print.
for some reason ultimaker cura, when saving gcodes, and i open them, they are completely empty (i open them with notepad and usually when this wasnt a problem i was able to see the gcode text so its not the way i open them, i think...)
OS: windows 10,
e.g. left is after problem right is before the problem
this problem is fixed but the printer still skips to 99%
Edited by AndreLuis
    Posted · ultimaker cura 4.13.1 and flying bear ghost 5 skipping to 99% of the print.
    i tried to reset the settings and even if it now shows the gcode but the printer still skips from 0% to 99% or directly 100% for some reason, i should try either reinstalling or changing slicer
    • AndreLuis changed the title to ultimaker cura 4.13.1 and flying bear ghost 5 skipping to 99% of the print.
    4.13.1 is fine and this problem has not been previously reported by anyone (so far as I know).
    Are you saving the files to the hard drive and then copying them to an SD card(?), are you using some other means to get the gcode to the printer?
    SD cards can develop bad memory sectors and when Windows copies or writes the file it doesn't check for errors first.  That means a file can be written to a bad  sector.  Windows handles the saving from Cura so saving directly from Cura to an SD card causes the same issue.  You can try re-formatting the card.  That's the usual fix.
