This is a discussion forum, not a place to write your own tutorials. People wanting to set it up are probably going to do a Google search for instructions rather than come straight to the forum. A good place might be an appropriate subreddit for that printer.
Quick Setup Guide for Elegoo Neptune 4 Printer Profile & Settings for Cura 5.4
- cowboyz1 changed the title to Quick Setup Guide for Elegoo Neptune 4 Printer Profile & Settings for Cura 5.4
Useful Cura related information in the Cura forum, don't see a problem with this.
6
Hi, is there a reason why your print area is 235x235x270mm? In the manual it says that the print area for Neptune 4 is 225x225x265mm
6 hours ago, NF_99 said:Hi, is there a reason why your print area is 235x235x270mm? In the manual it says that the print area for Neptune 4 is 225x225x265mm
I have absolutely no idea about Elegoo printers, but it could be like a Creality Ender-3 / Ender-3 v2, officially the build volume on those is only 220x220x250, but the plate itself is 235x235 and with a little tweaking you can get it to use all of that space. Now they've spoiled everyone's fun with the Ender-3 V3, which still has a 235x235 plate, but has physical blockers installed on the machine to prevent it from going outside a 220x220 area.
1
I followed your guide and upgraded to Version 5.5 from the provided version 4.8 with my Neptune 4, copied all the settings across etc but the print speeds since moving across have been terrible. One piece that was 3hours 5 mins with 4.8 are now taking over 8 hours with the exact same settings? Are you finding a vast increase in print times?
5 hours ago, furyzetec said:I followed your guide and upgraded to Version 5.5 from the provided version 4.8 with my Neptune 4, copied all the settings across etc but the print speeds since moving across have been terrible. One piece that was 3hours 5 mins with 4.8 are now taking over 8 hours with the exact same settings? Are you finding a vast increase in print times?
Have you tried deleting the profile you copied across and adding the printer from scratch following the instructions in the initial post?
- 2 weeks later...
Yep, I tried your method first before trying any other settings. |Even upping the print speeds seemed to do nothing and the edge bed adhesion was worse than the elegoo version.
- 1 month later...
On 11/11/2023 at 6:04 PM, furyzetec said:Yep, I tried your method first before trying any other settings. |Even upping the print speeds seemed to do nothing and the edge bed adhesion was worse than the elegoo version.
You can only upgrade cura to 5.4 ... 5.5 doesn't work with neptune 4 from what I read online
- 1 month later...
Most helpful thing that came up in my Google search, thanks for sharing the work with others.
- 4 weeks later...
On 12/27/2023 at 12:30 AM, ptllll said:You can only upgrade cura to 5.4 ... 5.5 doesn't work with neptune 4 from what I read online
Oh wow, thanks! I didn't realize that just copying the settings from one version to another wouldn't be enough! Now I'm beginning to think my two recent big failed prints are probably related to the software and not bed leveling and z height adjustment
- 6 months later...
I'm assuming that these settings are for PLA, as I managed to print a bird' nest with them using PETG?!
9 hours ago, Chrisalis said:I'm assuming that these settings are for PLA, as I managed to print a bird' nest with them using PETG?!
The machine settings and start/end gcode shouldn't matter for different materials. Changes in the quality profile (mainly temperatures) are the important part there.
cowboyz1 4
There is also a very short Youtube Video that shows this process. If I have the time to find it I will post it here. Otherwise this process worked perfectly.
