4 hours ago, rsalasidis said:Not sure how many settings I am losing, but I can reload a project, and that has many of the settings already identified.
If it's just the user directory, that's usually just whatever printers you have set up. I can't remember if that covers what quality profiles are assigned to each printer, but if any are missing try going to Preferences > Configure Cura > Profiles, there's an import button in the top right, your quality profiles are stored in the quality_changes subfolder.
And if that's the only directory you had to rename, it probably means there was a conflict between a printer you had set up and an updated definition for it in 5.5.
rsalasidis 0
I renamed the cura.cfg -to cura.cfg.old - it did not make a difference
I renamed the user directory in the %APPDATA%/cura/5.5.0 directory to user.old, and that WORKED
It RAN
