I'd just swap the cores to see if the error moves or not.
If the problem moves when you swap cores left/right then it's a core. You can't use the printer unless both cores are able to heat up because that is required for active leveling. I suppose maybe you can skip the active leveling with the tweaker tool. Every um3 comes with 3 cores: 2 AA 0.4 and one BB 0.4.
If the problem *doesn't* move then I'd suspect the cable going into the top of the print head. It's common for the cable to pull too hard. If you remove the rear two screws in the head then the rear half of the head pops off and you can see a connector. Push that back down hard. Also when putting together use some paper as a shim to hold the cable so it doesn't pull on the connector.
You can get to the log file with ssh. If you are comfortable with ssh. But you first have to put the printer in "developer" mode which just lets you ssh into the printer. username/password root/ultimaker. When printer is in dev mode it shows the ip address on the display at the top. You probably can't get into dev mode until you fix this problem unfortunately. Once your printer is in dev mode, leave it there forever in case you get problems like this one again.
Use journalctl to dump the log file (google it). For example to see everything logged since the most recent boot do:
journalctl -b
gr5 2,224
journalctl -b
