Anycubic Kobra 2 Plus - no thumbnail and statistics via cloud-universe and printer display
alawrak
Posted (edited) · Anycubic Kobra 2 Plus - no thumbnail and statistics via cloud-universe and printer display
I have an Anycubic Kobra 2 Plus printer. I use Cura because I like it. However, I have a problem, I would like to send files to the Cloud from Anycubic, but it is not possible with files from Cura, when g-code is saved, for example, from PrusaSlicer, AnycubicSlicer everything works fine.
When I put it on the pendrive and into the printer, everything is fine. However, no parameters are displayed on the display, such as temperature, filament type, print time, table temperature, and there is no thumbnail (even if I add it to the gcode, it should be added).
When I send the file to the cloud, even more data is missing, the worst thing is that I cannot print the model cut by Cura remotely, only via a pendrive.
It shows below what they look like with Cura and with other slicers.
What should I do so that I have all the parameters in g-code and the thumbnail.
cura.thumb.png.2fa4ec80569978fe73c516c6d98a29a1.pngAC.thumb.png.a6377740a2875c296c0ac4c5608a0bcc.pnglcd.thumb.png.ac3b880112626d63e52e98a49c8c155e.png
Edited by alawrak
    • alawrak changed the title to Anycubic Kobra 2 Plus - no thumbnail and statistics via cloud-universe and printer display
    Because thumbnail is not generate by Cura in the Gcode. As Ultimaker doesn't use this solution they haven't added this option ( it works with PrusaSlicer because they have this option embedded in the software ). You can do it by using a postprocessing script as well as certainly your data missing informationsf for the Cloud. But you should ask this question on an anycubic forum.
    Edited by Cuq
    @Cuq I'm not sure if this "PRINTANDGO" plugin is an alternate to cloud and no clue if that might help!
    Although i found 2 plugins when i search for cloud.
    Edited by fc2kool
    Posted · Anycubic Kobra 2 Plus - no thumbnail and statistics via cloud-universe and printer display
    It not suport Kobra 2 Plus
    I generate thumbnail, but it dont show.
    How move "Slice button" to see what is under ? Is it the bug or what ?
    I wi
    10x10x03.gcode
    you have a thumbnail description in your Gcode but is it compatible with this machine ? I don't know ...
    In PrusaSlicer the settings are
    Could be possible your machine is especting a 230x210 image size and not 300x300 ?
    The size of the image does not matter, I will add that when I copy the image code from Cura to the file where we have the Prus code, the image is displayed correctly. Until there is an update, I will have to use PrusaSlicer, but I like Cura better. And from what I noticed with Cura, the prints are much better with the same settings.
    Maybe the difference is in the code type. PrusaSlicer uses Marlin 2, while Cura uses Marlin. It is possible that there is a problem here, and will Cura have support for Marlin 2?
