How to use C# to develop Plugins?
AaLily
Posted · How to use C# to develop Plugins?
Cura 5.5.0 points out that developers can use C# to develop Plugins. But I can't find any documentation or examples, can anyone help? Thanks!
Quote
Engine Plugins
Introduced infrastructure for Engine Plugins; Plugin developers can now hook into and change the actual slice process using a programming language in which they feel comfortable: C++, Python, C#/.NET, Dart, Go, Java, Kotlin, Node, Objective-C, PHP, Ruby
In this initial version, plugins can hook into the following engine slots:
Modify generated gcode, postprocessing it per layer
Generate Infill patterns
Modify extrusion paths
Listen to a broadcast of all Settings
