Per model settings: changing Wall Line Count works. Infill Line Directions is just ignored.
Go to solution Solved by Slashee_the_Cow,
Posted · Per model settings: changing Wall Line Count works. Infill Line Directions is just ignored.
The titel of the post says it all. Per model settings: changing Wall Line Count works. Infill Line Directions is just ignored.
I am printing a single object and instead of changing the profile itself, I wanted to override certain settings via "Per Model Settings" > Mesh Type: Normal Mesh.
Why is "Infill Line Directions" simply ignored? If I change it directly in the profile it respects the angles I am providing.
Thanks,
soh
    • Solution
    Works fine for me in 5.6:
    Bottom: normal model
    Bottom right: cutting mesh with custom infill line directions set.
    Top: model with custom infill line directions set.
    If you could upload your Cura project file (.3mf) it would help us investigate any problems that might be causing this.
    Sorry. I am an idiot. I meant Top/Bottom Line directions but then I changed Infill Line Directions. Duh 😞
          • Heart
        • 4 replies
