Feature suggestion: Sound just before nozzle is fully heated
jino
Posted · Feature suggestion: Sound just before nozzle is fully heated
Just a beep say 5 seconds before the printer actually starts printing. I always want to grab the string that comes out so that it won't melt on the nozzle or create a bump. At the moment I'm throwing myself at the printer when the head starts moving, cause I don't have the attention span to sit and wait for the nozzle to heat up :)
    You can write this into your start.gcode (if you have an UM1; you would have to switch to flavor 'RepRap' with an UM2):
    M300 S1000 P1000
    G4 P5000
    • 2 weeks later...
    Lol! I know what you mean!
    Hi, sorry for the late reply, that sounds good, but can't find the start gcode tab? I'm using 14.01, and there's nothing beside the Plugins tab..
    Because you obviously have an UM2 and the (very reasonable) setting 'UltiGCode' for the 'flavour' in the machine settings (cf. my post above).
    Interesting stuff :) i have to start playing with gcode a bit it looks quite fun.
    Does it change anything in terms of quality?
    Ah, yes, I'm one of them new casual users, we never read text that is put in brackets.. Ok, I tried that but I didn't get any sound, but I think it waited for awhile.. but then it started extruding way too slow..
    Hmm. Somewhere on these forums is how to get the UM2 to print in "rep rap" mode. There's a couple tricks - it's very simple but there something.... I forget. Sorry.
    Ok i will dig in the forum to find something :) thanks
    Ok, I don´t have time to look at the moment, let us know if you dig something up :)
    This is the start G code I have in cura in order to know when the machine is heated
    ;Sliced at: {day} {date} {time}
    ;Basic settings: Layer height: {layer_height} Walls: {wall_thickness} Fill: {fill_density}
    ;Print time: {print_time}
    ;Filament used: {filament_amount}m {filament_weight}g
    ;Filament cost: {filament_cost}
    M190 S{print_bed_temperature} ;Uncomment to add your own bed temperature line
    ;M109 S{print_temperature} ;Uncomment to add your own temperature line
    M300 S1000 P1000
    M300 S900 P500
    M300 S800 P250
    M300 S700 P125
    M300 S600 P125
    M300 S400 P75
    M300 S300 P37
    M300 S200 P500
    M300 S1000 P9
    G4 P3000
    G21 ;metric values
    G90 ;absolute positioning
    M82 ;set extruder to absolute mode
    M107 ;start with the fan off
    G28 X0 Y0 ;move X/Y to min endstops
    G28 Z0 ;move Z to min endstops
    G1 Z15.0 F{travel_speed} ;move the platform down 15mm
    G1 F200 E7 ;extrude 7mm of feed stock
    G1 F{travel_speed}
    ;Put printing message on LCD screen
    M117 UltiMaking...
    The bold part of the Gcode Makes a kind of music sound, then pauses three seconds (where I check that there is enough material about to extrude), and then starts the procedure to do a print.
    While printing from SD card
