Posted · Upgrading an UM2 with an UM2+ feeder?
Hi all,
I am planing to upgrade my UM2 with the geared feeder from the UM2+. As my UM2 already has the UM2+ hotend, I would like to avoid the high cost of the full UM2 Extrusion Upgrade Kit. If I understand it correctly, the new geared feeder requires a reverse direction of rotation. Is there a reason not to do this reversing just in the firmware (I use Tinkergnomes Firmware) and keep the UM2 feeder motor?
Reiner
    It is done in the firmware. Because there is an added gear in the extruder, clockwise becomes anti-clockwise. The firmware instructs the motor to rotate in the other direction.
    As far as I remember, the reason to include a new stepper for the extruder was because how the gear attached to the motor shaft (and the length of the motor shaft).
    Okay, so I would need a new motor anyways?
    I checked the Bondtech extruder and that one also states UM2+ as a requirement so it also might need the longer motor shaft?
    Like I said, because of the motor shaft (length and/or shape).
    Hmm, strange. I would contact them and ask. An Ultimaker 2 with an upgraded extruder and hotend, for all intents and purposes, is an Ultimaker 2+. I am pretty sure many Ultimaker 2 users that already had an Ollson Block upgraded with a Bondtech extruder.
    Okay, I will check with them.
