Hello Daid,
I print with the Cura 14.01 and the surface from my object is smooth. I print a boat jetdrive. Last days I test the cura 14.03 and the result is a surface with many bloops. I test with the same parameters and reduce the speed for the outer shell.
Then I test the 14.03 testversion, a little bit better, but the gcode from the 14.01 is better.
Little objects the result is a little bit better, bigger with circles a disaster.
What can I do. Should I send you the gcodes?
Thorsten
polar 0
on sunday I wanted to print a small wing (using an 13.x cura version) and discovered the noise in z direction (z being the span direction), and the trailing edge was kinda jagged. Not so nice, already thought of using netfabb as this prints in z perfectly and a nice sharp and regular trailing edge but on the other hand seems to do some decimation in xy, resulting in a airfoil which is not totally smooth (and nf has some additional issues)
But then I found (http://umforum.ultimaker.com/index.php?/topic/4601-cura-toleranceaccuracy/) discussing exactly this and your accuracy fix in 14.03, very happy I downloaded it and sliced (ok it took longer than with 13.x but who cares, still fast enough). then I started printing and the printer sounded like it's going to die at the leadingedge and at some small 4mm diameter holes in the wing, After finishing the print the z direction was much better than in 13.x but still not as perfect as in netfabb, trailing edge was nice. Now the 14.03_test sliced code is running, the speed issue is gone! Thanks
will comment on overall quality after is is finished, but in the graphic preview it looked fine.
