8 hours ago, Slashee_the_Cow said:Actual advice:
Close Cura. Uninstall Cura. Go to %APPDATA%\cura\ and delete (or move them somewhere else is probably better so you can restore stuff, especially if this doesn't fix it) all its contents. Reinstall Cura.
Just tried the above and it still crashes on startup.
Slashee_the_Cow 541
Not sure if this helps, but I'm 90% sure whatever version of Python you have installed doesn't matter - it includes its own interpreter (or at least it does for post-processing scripts written in Python, spent over an hour trying to figure out why the hell my f-strings weren't working).
Python segmentation faults are usually an extension written in another language trying to reach memory out of bounds or hitting a recursion limit... but that still doesn't help you.
Actual advice:
Edited by Slashee_the_CowLink to post
