Posted · extra design in my layers
Hello everyone,
This one here has been stumping me and I'm trying to find out why this seems to re-insert an additional line of the cut out mesh a few layers above. It adds a little time to the print and I'm trying to get the print time down. Any and all help is appretiated.
    I'm putting good money on that being Top/Bottom > Bottom Layers. You could change it relative to Top/Bottom > Initial Bottom Layers (so bottom layers = initial bottom layers - cutout depth) but you shouldn't. It's there to make sure the design is strong,  consistent and smooth.
    Something everybody's gotta learn one way or another: if you try and beat the system to print it faster/using less filament, it will cost you more in the end with failed prints (or substandard prints). Pick your idiom. "Slow and steady wins the race" is the first one that comes to mind.
    That shouldn't happen.  It may be a misplaced layer.  If there is a bad edge or flipped surface within the model (likely within the cutout) you could get something like that.
    Have you tried running the model through a repair program like MS 3D Builder?
    If you load the model, set Cura up to slice the way you want, and then use the "File | Save Project" command, you can post the 3mf project file and it will contain the printer, the model, and all your settings.
    Posted (edited) · extra design in my layers
    I respectfully disagree. Here's my "coin shaped thing with a 0.2mm Slashee cutout™":
    Let the record show that I am using 0.2mm thickness for all layers, even the bottom:
    And that the top and bottom consist of four layers:
    With that out of the way, here's layer 1:
    It has the Slashee cutout, as expected.
    Layer 2:
    All skin, as you would expect. Layer 3:
    Still nothing but skin. Layer 4, the top of the Initial Bottom Layers:
    Wouldn't you know it, all skin.
    Layer 5, if you please:
    There's my Slashee cutout! I knew I left it somewhere. Cue layer 6, for demonstrative purposes:
    All infill. The Slashee has had its four layers in the spotlight.
    Why does this occur? I'll refer back to figure 3:
    The print above the Slashee has four bottom layers. The first three are integrated into the initial bottom layers, but that does not provide four layers of skin above the Slashee, so it generates skin for the fourth after the initial bottom layers have ended, because it started a layer later.
    Edited by Slashee_the_Cow
    added layer 6
    • Like 2
    Thanks Slashee.  That's a much better explanation of "Excepted Behavior".
    @Kraven33 do you see it?  There are going to be "bottom layers" equal to your setting over the cutout.  You can adjust the "Skin Expand Distance" to get rid of some of the ins-and-outs so it prints smoother but if you have asked for 4 bottom layers and the cutout is less than 4 layers deep then yes, there are going to be additional "cutout shaped" skin areas to make the bottom count over the cutout = 4.
    If the cutout is deeper than "bottom layers" then it looks like the normal situation where the "real" bottom layers on the build plate stop, the cutout continues up, and then the cutout gets capped with 4 bottom layers.
    (Could've been a model error though.  I did say "maybe".)
          • Heart
        • 7 replies
