error " layer height"
schoub
Posted · error " layer height"
Hello everyone;
recently, when saving the Gcode or the project, Cura tells me "error Layer Height" and saves neither the Gcode nor the project.
I reinstalled CURA 5.6, used the standard layer height profile, I don't understand .
Do you know where this error message might be coming from?
    I really can't see much in that screenshot because it's such a low resolution and not in my language - but go to the Quality section of settings and make sure Layer Height and Initial Layer Height are both set to valid values (by default on a 0.4mm nozzle I think they're 0.2 and 0.3 respectively, but the main thing is that their boxes are grey, not yellow or red).
    If they do look valid then please post a higher resolution screenshot with the quality settings open (I can probably manage the translation since I know the settings). Also, try a slice that generates the error, then go to Help > Show Configuration Folder and upload the cura.log file.
