2 hours ago, LegendOfZach said:Any idea when 5.7 comes out?
I wouldn't hold my breath, 5.6 only came out a couple of weeks ago and major releases are usually at least a couple of months apart. At least you can download the profile for the KE from that pull request so you don't have to start from scratch (or more realistically, from another Ender-3 variant).
Can't help you with the WiFi though. My lowly E3V3SE doesn't have it. I do run it over WiFi, but that's because I had a Raspberry Pi I wasn't doing anything with laying around so I installed OctoPi and then OctoPrint connects to the printer over USB.
Just know that whatever hassle using Cura is over Creality Slicer, it's worth it. Creality Slicer is forked from a fairly old version of Cura so its slicing engine isn't nearly as good (and I'm not sure if it was designed to do that, but the first thing I sliced and printed with it had no bottom layers, just an uninterrupted view of the infill... WTF?), my experience might be worse than other peoples' but nothing I sliced in Creality Slicer came out right (although that was 3 or 4 things before I gave up).
GregValiant 1,489
I see there is a pull request HERE in for the KE. It appears to have been OK'd so it might make it into 5.7.
Someone else will have to comment on Wifi.
LegendOfZach 0
