Hey Slashee_the_Cow thanks for your answer. The error vanished without anymore change from my side from one day to the other. I have no clue what I experienced there.
1 hour ago, EmilTischranke said:Hey Slashee_the_Cow thanks for your answer. The error vanished without anymore change from my side from one day to the other. I have no clue what I experienced there.
The best way to fix any technical problem: show it to someone else and it disappears.
Slashee_the_Cow 463
Does the log file just end there? If there's anything after it could be useful.
Also, sometimes when my slicing fails if I just move the build a little bit on the bed it will slice successfully, so can't hurt to try that.
You should probably also submit a slicing failure on the Cura GitHub page so the devs can look at it.
