5 hours ago, assaero said:(Yes, I like filesystems, why does everybody ask this ;D)
I didn't ask, personally I love BTRFS. I tried linking the Cura config directory on my Linux install to my Windows one (automounts at boot) but found it annoying that since the recently accessed files and last saved/loaded path are in completely different locations on the different OSes they got wiped each time I switch.
So I just set up rsync to sync the whole config folder except cura.cfg at boot 😄
IRobertI 521
Click on Help->Show Configuration Folder and it'll open up the folder that holds the settings for your install.
Slashee_the_Cow 619
On Windows the configuration folder location is %APPDATA%\cura\<version number>. You can just copy+paste between computers, bear in mind that it won't automatically synchronise any changes. The only thing which you can make automatically synchronise is plugins installed (by signing in to an UltiMaker account in Cura before you download them, and then signing into it on your other devices).
If you're a little adventurous, you can make the whole thing by using cloud storage and either a script to automatically synchronise the folders or just a straight symbolic link to where the cloud data is stored on your computer, but in my experience neither of those works particularly well (mostly because however long it takes to sync changes from another computer is always slightly more time than it takes for what's already on my computer to overwrite it).
assaero 3
Thank you - I normally run it with an external drive anyway, as my design stuff is cloudsynced onto this drive (so that I have the cloud backup without depending on an internet connection) - I just put both main application folder and the config folder @IRobertI mentioned onto it and did a fs junction on all systems on it - this seems to help. (Yes, I like filesystems, why does everybody ask this ;D)
