Posted · Ringing on single wall print
what speed did you print ?
did you have the cooling fans on fully ? maybe the vibration of the fans could have added this wobble to the surface.
Ian :-)
    Nope, that looks surprisingly smooth coming from OpenSCAD, I'm used to seeing all kinds of faceting on those models.
    In that case I would look at slowing down the print and lowering acceleration as mentioned in the post I linked to.
    Don't slow it down! Just reduce acceleration.
    Here are the results of someone's experiment - only lowering acceleration helped - consider 1000mm/sec - posting #8:
    http://umforum.ultimaker.com/index.php?/topic/2532-prevent-ringing-wobbly-surface-after-sharp-corners/?p=18006
    HOWEVER, looking at his pictures and your picture they look quite a bit different. I'm not convinced that is ringing.
    It's official, that's the first time gr5 has NOT recommended to slow down :eek: Also, I already linked that post ;)
    The size of the artifacts is what threw me off as well but I figured if he slowed down and reduced acceleration we would remove those variables.
    :lol: :lol:
    Yes.
