In your balanced profile, what is your speed set to?
Is your s5 on a flat sturdy surface or oscillating back and forth? How fast are we talking about?
I glossed over zip being accepted, thanks Torgeir.
Here are the videos.
It is on a flat sturdy surface. I just accepted the default settings for "balanced" on this print. I will check the actual speed setting when I get back to my printer.
- Solution
To me, this looks fine. As long as you aren't experiencing any print quality issues, this is normal.
That vibration that you are experiencing between the outer-walls and the infill seems normal and is a factor of the extrusion lines being very small.
If it bothers you, You can set Infill Printing speed to slower, or You can also enable Jerk control and reduce jerk to 6-8mm/s(?) and that may likely help with the jerkyness on the infill.
If the S5 had input shaping then the vibrations could be much less, but for now we at least have jerk control in the slicer settings available.
- 1
Thanks for the response and reassurance. I will look into the jerk control setting.
- 2 weeks later...
Just wanted to put a bow on this, the jerk control setting was the ticket. The balanced profile had it defaulted at 50mm/s. I took it down to 20mm/s and the obnoxiousness was gone! @RaidenUltimaker, really appreciate you pointing me in that direction.
- 1
Torgeir 267
Hi @AD5CDA,
You may zip the video file the attach in here, should work.
Thanks
Torgeir
