Robert, you show 45 degree in red but if you have a .4mm nozzle and a .1mm layer height you can change that possibly to a .1 to .4 ratio or 14 degrees.
Why build a perimeter (shell) in the open air
so that the material all
falls down (driven by gravity)?
Because often it works anyway - gravity is not a significant force sometimes and sometimes (if the fans are cranking on 100%) you can actually build a shelf hanging over nothing. The UM and UM2 are pretty good at this.
IRobertI 502
If I'm understanding you correctly this would only work for very very small overhangs. Something like <1mm. If the overhang was bigger than that you would have to modify a lot more layers and you would destroy the geometry of the model in the process. For example, if the model had a profile like a staircase, instead of having individual steps it would turn into a diagonal line which is probably not what you'd want. Or even if it was just a single overhang, it would still destroy the intended profile. The green part is the intended model (let's ignore it's printed the wrong side up
and the red is what would be added. It would completely destroy the model.
Not sure I understand the second suggestion. Do you mean it should be a concentric infill pattern, building outward? Not sure how the infill could be built without eventually stepping out over the edge if there's an overhang, regardless of order or pattern. The shell is already being printed from inside to out. No matter which order you print in, eventually there will be air underneath the plastic.
