CC 0.6 Print Core Stuck in Printer
Go to solution Solved by Zabi,
Posted (edited) · CC 0.6 Print Core Stuck in Printer
I’m using the Ultimaker S5 currently running on version 8.2.0. I ran a print on it and when I came back a couple hours later, there was a huge blob of filament all over the nozzle as you can see in the first picture. I removed the most of it however couldn’t get the bits on the inside. I tried to remove the print core out of the printer itself but to no avail. There isn’t any filament in the nozzle stopping it from coming out so I don’t know whats holding it in. My guess is that there may be filament holding it in place, but not sure
Edited by Zabi
Wanted to add more information
    • Solution
    Posted · CC 0.6 Print Core Stuck in Printer
    Solution:
    I heated the print core up to around 250 degrees Celsius and as I pulled the core out this time it came straight out.
